I have had this problem for a while, and would like to find a solution.
About 2 out of 3 takeoffs in the 97 Challenger, when I throw the throttle to 100%, it will hit about 5000rpm and not go faster, making the time to plane WAY too long.
Sometimes, it will go straight up to 6500 and plane in just seconds.
I just replaced a bunch of RAVE valve components, including one valve and all the rubber and plastic components trying to fix this.
Today, I experimented and found that if I put it in neutral and let it bounce off the rev limiter for about 5 seconds before taking off, it will take off just fine, straight to 6500 rpms. I just put it in neutral, bounce off the rev limiter for about 5 seconds, then quickly put it to idle, put it in gear, and slam it into 100% throttle and it hits 6500 and takes off like a champ!!!
What could be causing it to take off slowly in this case? I don't mind having to rev it in neutral, but it would be nice to not have to do this.
