My 96 gsx has had this problem since last year but it is getting worse
when i plug in the lanyard i get my 2 beeps all systems go But then there is a pause and then i get 4 more beeps all systems no go i do not blow any fuses, in the past i was able to pull out the fuses put them back (the same fuses) and this would solve my problem, plug in the lanyard get 2 beeps and go, and as long as i didn't let the seadoo sit for more then a day or so it would start everytime but after two days or so of no use i would be back to square one with the 2 beeps pause then the four beeps
now pulling the fuses trick doesn't work any more
i did notice after i got the four beeps i would hear a click noise comming from what i think is the rectifier?
So the last time i checked fuses all good then i poked around the rectifier alittle bit plugged the lanyard in and it worked i got my 2 beeps engine started
i know these tricks are not going to last much longer
does anyone have any idea as to what this could be?
Thank you for your time and help
jack
jack
