hey i changed my rave valve bellows and the caps and top retaining springs rings that hold them on...put the seadoo in the water and at wot i got my top speed and max rpm 7080 for about 10 secs then it drops right down to 6400 rpm and about 61 mph on the speedo instead of the 70 i was just getting... when i check the rave valves remove the black cap one of the bellows had come half way off the top spring ring too...i tried siliconing it when i put it bac together... water test same thing just this time the one i didnt silicon came off...i siliconed them both water tested it and the one that came off the first time came off again...now there is some oil in the bellows itself could that be the reason? like should i put new orings in it? by the way this is a 1997 1/2 gsxl...now do some of thise skis have a pressure relief valve in the line that goes from the sileinod to the crank could that be way...anyone with any info that would be great thanks
