So I'm in the process of changing pump oil and I am trying to figure out how to properly install the cone with the anti rattle device. The manual says to insert pencil into lube fill hole and push on the slider tab ( I assume towards the impeller shaft ) then hold tab and torque screws. Then remove pencil to release locking device. Can someone clarify / explain process a little clearer so I am sure I'm doing it correctly ? Thanks
