With riding season fast approaching, members may start looking for the Quicksilver oil for the Seadoo's.
I know, from members online, that some of the Walmarts don't stock the "Synthetic Blend" or the "Full Synthetic" in their stores. One member said the manager told him if he had the UPC code, he could get it ordered and stocked in their store.
I found this oil in the automotive side of Walmart, not the boat (sporting goods) section. Looking at tht automotive oils, you should see gallons for sale that are Evinrude, etc.... If you do not see the Quicksilver brand of low ash, non NMMA oils, you can use one of the UPC codes below to see if you can get the manager to order it for you.
I have used this oil for 4 years now in my 97 model 787cc engine and the results from a low carbon build up on my RAVE valves have sold me on it's oiling properties.
The UPC code for the "Full Synthetic" is.....74506167708 with a part # of 92-85015Q03. The "Synthetic Blend" is.....74506148072 with a part # of 92-858015Q03.
If you are buying a ski, especially the one from the 90's, not sure of what oil the previous owner used, you can drain the tank of oil by removing the bottom hose from the oil tank, put it back on then fill your oil tank with the "full synthetic". You can go from mineral to synth blend or either of these to full synthetic but you can't go from the higher quality oils back to the lower quality oils without a full clean out of the oil injection system.
You can leave the oil in your rotary chamber if you like but if your moving from mineral to synthetic, I'd recommend removing it to get the full protection from this higher quality oil.
Feel free to post here or PM me if you have any questions about your oiling needs.:cheers:
