Hello. I just purchased a 97 Challenger 1800 with the twin 787s. My friends and I took it for a test drive before buying and ran a compression test. We had 130-135 on each plug. It seemed to run fine on the test drive. We transferred it and took it to the river last weekend and it seemed to run fine there too.
At this point we have only noticed two problems...
1. We are getting water in the engine compartment. Not a lot, but enough that we have to run the bilge for a minute or two every couple hours. It's hard to isolate where it is coming from. I have heard it could be coming from the exhaust?
2. After running for a while, I noticed a light splattering of black oil around the furthest back black cap (I am assuming the cap is a cover over the RAVE assembly) on the starboard engine. When the motor is running, I felt a puffing of air and oil coming from around the bottom of the cap. I slightly tightened the cap, wiped the area clean, and took the boat for a spin. There was no oil spray after that. Any thoughts? I have heard those caps are not meant to be tightened down.
Any other advice you can give about this boat as far as maintenance or things to look for? I would greatly appreciate it.
