I would not advise buying a buds system...BRP has that system on lockdown and if it already isnt a paperweight, it will be once you try to use it.  From what I know that system uses the internet to communicate to BRP and when it comes from a different IP, it will be shut down.
Its almost a requirement when you are working on DIs though...I have the tech video for 01s and its AMAZING what you can do with buds.
The previous owner had a heck of a time with BRP on my programmer getting it out of my name and into mine.
Rick...on your boat MPEM if you got it working correctly then go and swap the MPEM. You are going to be able to test it better that way. Obviously the first thing is seeing that it blows fuses or not, then put the key on. Im sure the dealer didnt erase the key, so it should work.
My system will blow a fuse if the diode is bad, and if its screwed up to the point that it will not communicate with the key...I would see that as well.
