Andrew gti130
Hey guys my check engine light came on with the error code p0524 which is oil pressure or oil pump, checked the dip stick to find it dry, so I filled up the oil but that light didn't go away and the ski was in limp mode. If you have this problem check your oil level and oil filter to make sure they are normal. Once they are good turn on the ski and plug your water in, idol the rpm at 3000 for 15secs and bam! The light and limp mode should go away. No need to pay the dealership money for them to plug a computer in and feed you lies about faulty sensors. If your oil filter is crushed then you might have a faulty oil pump.
