Hi.
My writing is not smooth using a translator.
I'm running 260. However, there is a shortage of output.
Cylinder pressure, ignition plug replacement, ignition coil replacement. Supercharger maintenance. We did.
There's a little bit of relief on the ground, but it goes up more than 7,000 rpm. But it doesn't go up more than 4,000 rpm when you go into the water.
Finally, the 260 but 215 instrument cluster was fitted. The left gauge does not work.
Is it because of this? 260 I'd like to install a new instrument panel.
Is there a low output above the instrument cluster?
