L lilpain New Member Jun 6, 2010 #1 I just replace all my gray lines with black ones.I want to know how can I hook up my water hose to my seadoo .
Bills86e Premium Member Premium Member Jun 6, 2010 #2 WhaT? You loose the hose accessory connector? Brouse Seadoowarehouse.com microfiche your ski yr/ml click on cooling system.
RutlandRacing New Member Jun 7, 2012 #4 They is a grey hose with a red valve you need a special fitting for your hose or you can just make your own.
red2blue New Member Jun 7, 2012 #5 lilpain said: I did but how do I figure out were to conect my hose to Click to expand... On a 4tec, the hose connection is to the left of the pump as you look at it from the rear.
L LouDoo Premium Member Premium Member Jun 7, 2012 #6 You need to post this in the 2-stroke PWC section. Lou
