Puttyinyahand
Hi Guys,
Newbie here from over the pond, hoping you’ll be able to answer this for me.
Seadoo 04 GTX SC stopped and have lost fuel... ran through everything and it looks like I’m not getting switched earth from ECM to turn on pump.
Have swapped the ECM with a good 04 RXP and pump runs as it should to prove it.
Question is can the ECM’s be repaired with this fault... failing that can it be rigged to run a separate fused relay for earth switch?
cheap replacement ECM’s over here are not readily available so any help would be appreciated and I’ll get saving for a new one if that’s the only fix
