speedluver
2001 Islandia 240HP
Engine Serial# 0E385928
I'll tell the longer story, because sometimes that helps people with similar problems see patterns. My boat had been running pretty well the few times I'd had it out this season. A couple weeks ago, I went over to the dock to take it out, and it just cranked and cranked with no firing at all. I didn't think that I heard the fuel pump like I usually do before cranking. I unsuccessfully tried all of the little tricks and such that I have learned in the past 8 years I've had it (and spent cussing at it and swearing I was selling it the next day) before I gave up for the day. I went out the next morning and still had no luck getting it to fire, just cranking and cranking.
I worked on it over the next couple weeks. I had spark at all cylinders. Luckily, my friend had given me a Mercury service manual a couple years before for an unrelated issue. I followed the manual and determined that the electric fuel pump in the VST was not getting triggered to run by the ECM. The lifter pump didn't seem to be kicking on either. Both would run just fine when grounded directly, and fuel pressure was good when grounding the VST pump. According to the service manual, I was looking at a bad connection on the black/red negative wire that runs from the VST fuel pump to the ECM, or a bad ECM
Following some advice from a thread on here, I disconnected the ECM pigtail and checked continuity on the PIN 2 wire from the pigtail to the terminal connection on the black/red wire of the VST fuel pump. I showed good continuity. Resigned to the fact that I must have a bad ECM, I plugged the ECM connector back in and started cleaning up my tools. I still had my multi-meter hooked to the one of the fuel pumps, and I figured I'd turn the key to "ON" one last time. When I did, I saw the voltage drop like it hadn't before, so I went ahead and tried to start it. It fired right up.
Now, I figured that I just had a bad connection in the pigtail connector of the ECM, and the reconnection and/or cleaning it out a bit must have taken care of it. I shut it off and restarted it a few times. I went out and got some more oil and gas, and decided to take it out for a test cruise a couple hours later. I went about 5 or 6 miles to one place, and I stayed there for about an hour. When I went out to leave, it started right up and I went another 4 or 5 miles to another place. I was there another hour before I started it up without issue and went 5 miles and stopped at the beach on the way home to get in the water and cool off. After 45 minutes or so at the beach, I went to leave and got the same cranking and no firing. I've had a lot of warm and cold start problems with this boat in the past, so I can usually tell when it is going to start before I completely discharge the battery. It seemed to be the same problem as before, and once again, I didn't hear the fuel pump kicking on. I popped the hatch and tried disconnecting/reconnecting the ECM pigtail and starting a few times. No luck. I figured I'd leave it unplugged for a little bit like I did at the dock when it first started working again. After 5 minutes of us getting ready to hook up to a boat for a tow, I reconnected the ECM and tried one more time. It fired right up. I thanked the people for offering the tow and took it the last few miles home without issue.
I am stumped. The beach starting issue could have been something completely different, but it was weird how 5 minutes of the ECM being disconnected seemed to fix the problem again. Are these symptoms of a failing/bad ECM? Does disconnecting that one ECM connector for a few minutes kill all power to it and essentially reboot or power cycle it? Maybe I just need to clean the connection up a bit better and apply the dielectric grease. Is there any other sensor or safety feature that will not allow the fuel pumps to operate to prevent starting or running?
Thanks for reading and any advice.
