Well, I sucked up a tow rope, and had to cut it off. In the process i learned that there's a plastic drive shaft protector. I also learned that a tightly wound rope breaks them easily :cheers:.
I've been reading, and have seen alot about not needing them. However, a few posts elude to cutting them off, but leaving a little piece on the engine side, to help the water seal to the engine compartment. Mine was totally broken, so it's all gone.
So the question is, do i need at least a small piece of this protector remaining on the engine side, or is it ok to run with it completely removed?
Thanks,
-jim
Thanks,
-jim
