seadoolovr
What is the coolest modification you have either done yourself or seen for a challenger 180. More power? lighting? seats? towing? you name it, what's out there?:thumbsup:
limarc - soundproofing is my next mod. Can you share any details of what product you used and how/where ?
Thanks !
the sound deading stuff you got with the adhesive backing is $176.00 a sheet now from AMI
Moochy, the steering wheel came w/ the remote or you installed it?
This is a standard seadoo wheel. We have made the remote fit inside.
We haven't got that far yet. I imagine w will just drill a hole through the boss into the steering colum and loop the power cables a few times, all alpine remotes operate on RF so there's no control cable to worry about,
Looking at the Sony remote you have you would not have it secure flush from the rear but take the centre piece out and mount in the existing hole ( possibly with a hub extender).
Mine will be 30mm closer to me by the time were done.
No worries, I thought a few 150 speedster owners would like what I've done. Remote placements in those boats are far from ideal. Looking at the remote in the 2012 model the driver can't even see what's on the screen! With the Sony remote the key will be the diamiter of the back on the unit, start looking at hub extenders too.
Jeez! I got the remote today. This thing is huge. No way it can be mounted in the steering wheel. It's big as mid-size turtle... I have no idea why they designed it so big. Now I have to find another spot for it... Any ideas are welcome.
Moochy, what's the diameter of your Alpine remote? I found the same steering wheel as yours and the opening is like 2". Maybe I'll be able to do it in the wheel...
Also how did you remove the steering wheel? I took the plastic cover off then the bolt that's holding the wheel and then what? Just try to pull it or there is something else to be done?
The hole In a standard seadoo challenger wheel is around 2 inches. My machine shop made the hole big enough to fit a mc20 remote. You need to be careful as momo wheels for example didn't have enough meat on them to mill out.
I'd need to see a picture of your current wheel but I reckon what you have is more like a car steering wheel where a rubber cover goes over the centre bit and the main part of the wheel is built onto the boss assembly that connects to your shaft.
What you would need then is a marine boss kit to suit your steering shaft then an adapter like what we are making to attach the new wheel assembly to the boat via nuts and bolts.
