Dougsnash
On my 'new to me' 1994 GTS, I have been experiencing intermittent hard to impossible starting. After an extensive cleanup, I am fairly confident in the test run capability of the fuel system and have verified with a spark tester that I am only intermittently getting spark to the spark plugs. I have trimmed both ends of the spark plug leads back and re-verified that I have a good ground path for the coil and MPEM. On a guess, I disconnected the MPEM from the coil so that the coil was being fed directly from the stator and verified I have good spark. The machine will start and idle with the MPEM disconnected from the ignition circuit and returns to very intermittent spark when the MPEM is reconnected. Thus, I am pretty sure the MPEM is in the process of failing. This is a 1992 vintage MPEM with external fuses and sockets with relays rather than the original 1994 vintage one supposed to be there. Another symptom of a failing MPEM is there is no voltage on the output to the buzzer/ overheat sensor.
Can someone with more knowledge on these machines confirm my suspicion that the MPEM is toast? Or, if I am wrong about a bad MPEM, point me in the correct direction. And if the MPEM is actually toast, where is a good place to find the proper replacement?
Thank you
Doug M
Thank you
Doug M
