Upallnight
How much slop is acceptable in the drive shaft carrier bearing? I'm having problem with my 1995 Seadoo Sportster. The engine runs fine and I can get the boat up on plane, but after 10-15 minutes of riding, the engine bay begins to fill with water. I turn the bilge pump on and it is able to pump out most of the water. The storage locker in the center of the boat is never wet. I grease the fitting, but notice that there is a line of grease on the under side of gray cover.
If I was to replace the carrier bearing should I also replace the wear ring on the pump? Because of this water issue I have only taken the boat out twice. Would like to get it fix by Labor Day.
TIA
TIA
