Bnelson
If you want to do a little check your own, pull the tank and look for the clock dial molding dates. There will be a year that reads 199 then the circle with the arrow pointing to the last digit just to the right of it. I think it's right to the right of the capacity of the tank that is molded into the tank. If that last digit is a 5 or 6 you're more than likely due for a tank. Damn, again with the date codes!!!!!!!!!!!!!!!!
EDIT: Your's should be a 5
Thanks man, I'll be pulling it here in a week or so to check when I start cleaning the hull.... Gotta track down an oil tank for it as the po had it converted to premix... And yes! These date codes again!!
