Chasm7X
I have a 95 657x that when you try to start it, it turns over for a split secong then stops, if I unplug the coil from the MPEM then it will turn over fine, would this be a bad coil or stator? I know the wire I am disconecting from the MPEM is the RPM sensing wire. Open to all ideas before I tear it apart. Thanks
