Hello. First time forum user. I have 2 1999 GSXL's both with the 951. That motor has great power. One has 40 hours & it's twin has 140 hours on it. Visually they're identical except for a newer seat cover. One problem I'm incurring is a sticking throttle cable. I juiced the linkage @ the carb & that helped a little last year. It didn't stick ON , but it has a bind. How do you physically check cable for a bind ? Removing it down by carbs is proving to be tricky. That's my first step. Second I'll inspecting moving parts on carbs for an issue. I know specific adjustments are necessary for both cable & carbs. Any advice ? Thank you.
