I stole power from the guages it hasn't been an issue it comes on when the key comes onView attachment 38449View attachment 38450
Fitting came in today for the egt.
I going out to the shed and going to try to install the gauge tonight. Do you guys have a switch to turn your gauges on or is it hooked into the wiring harness so it comes on when the ski is on.
No switch is preferable to me but I did notice Matt carbon fiber x4 did have a switch.
Yes I followed the Racepak instructions giving it it's own switch. I had a hole on the dash to fill. The rest of my skis have them wired in with the gauges though.
You have a taller impeller and tighter nozzles then I was using with those pipe and carbs. I would go with the stock nozzles to take the load off that new engine until you have it good and broken in.
The rev limiter under your MPEM in the grey box has timing adjustment on it. It would be a safe thing to back it off a degree or two. We can wait and see how the WOT temps are first though. If it's all good just let it ride.
Not trying to give you too much to think about just want to stay on the safe side of things.
So just use the purple for power coming out the gray box going to the gauges and the black for ground on the same plug?I just wired into the gauge power.
Yes, that's all I did unless you don't want it to come on with gauges and be a separate switch controlled circuit.So just use the purple for power coming out the gray box going to the gauges and the black for ground on the same plug?
Looking good. When the silicone between the Trim Fix and the housing dries you will not need the tie straps. I guess the gauge reads OK on the original magnet?
I like the turf choice, looks right with that ski.
