russianphil18
I have been rebuilding the 787 for about a month now. the reason for doing it was cause it wouldnt start and one of the cylinders was showing 90 compression while the other 155. well the top of that piston had dents in it everywhere ands even in the head. I pulled the piston off thinking that was the only problem and saw that the rod was moving up n down. I pulled the engine and while it was upside down to start to remove the bottom end i noticed metal was falling out of it. Obviously thats never a good thing. i was guessing that the pieces of metal were from bearings.
Pulling the bottom end off was more work then i thought. the starter housing is in the way of one bolt so the flywheel and that whole side had to come off. bought a flywheel puller and got that off today.
I found that the bearings on the bad rod dont exist anymore but i also saw that the rod doesnt have any bolts on it which would allow me to easily remove it. the rod is a solid piece attached to the crank. I have never seen this before so any help on how to get that off would be great.
The other bad thing is that the rotary gear is eaten up. how should i go about replacing that.
Im also looking for where i can buy a gasket set for the entire engine
advice? was/is this rebuild really worth it? i have pictures to show so ill try to upload the most important ones in as few posts as possible.
any help is appreciated. thanks alot
