I replaced all my gray fuel lines last year and cleaned the fuel filters in the carbs a few weeks ago, as well as the inline fuel filter. here is what it is doing now.
i can fire it up on my trailer fine, but regardless if it is cold or warmed up, when i shut it off and fire it back up on the water, i ALWAYS have to give it throttle to get it to start, it will not start without it. but it will idle just fine. then if i can barely touch the gas after its been idling and it sometimes just dies.
the times it does not die, it almost bogs out a split second then it hits and goes like a new one.
this sound like a fuel issue? top end is great, does not "miss" at idle or anything. just bogs itself out for a split second.
sometimes i have to let it crank and crank for about 8 seconds, giving it throttle before it will finally start on the water. even after i rode it for hours.???? any ideas?
p.s.- new plugs were installed as well and spark is great on it. rave valves were just serviced a week ago. but its acted this way all season.
