glsmohio
ok guys just rebuilt the carbs and redone the oil lines....here is the story:
problem 1----Started the engine. held oil pump open to prime the oil lines, shut engine off. ( it wasnt running right like it was fouling plugs.) pulled the plugs and they where full of oil and gas. turned the engine over with plugs out to get every thing out. Put new plugs in and it fired maybe one time for a half a sec. and then nothing. put 3 more sets of plugs in and no start. im getting way to much fuel. so my question is do you think i fu*ked someting up on the carb when rebuilding them or could it be that i reused the base gaskets for the carbs and now i have a vacuum leak? should i try new gaskets?
problem number 2--- when i put the key on i dont get two beeps ( i have installed a new beeper and tested it and it works fine) also when i put the key on my gauges does noting. Now if i take the key off and it the start button two times everything comes to life and it shows me where trim is gas oil temp and all that stuff. My gray ebox had a lot of water in it that i just found (pipe was leaking and spraying the the ebox and where one of the wires go in the box, the seal was broke bad) the pipe is all fixed now and i cleaned up the ebox. all fuses are good (3 in the ebox). I thought when i put the key on it should all come to life...any ideas???
thanks
Scott
thanks
Scott
