96 gtx 787
svtman
I have an issue with it cutting out intermittantly. Its seems like its loading up or lean but the plugs are perfect. Compression is good at 150 a cylinder carbs have been cleaned and readjusted and i have ran br7 plugs to see if it helped. I cannot figure this thing out. Any help would be greatly appreciated!
Don't change plugs all Seadoo's need BR8ES plugs.
You need to check the fuel lines, fuel filter and selector.
I know they all run br8 was just trying something different. Will check filters and lines are all good
Check the voltage regulator. 96's are notorious for this. Unplug red wire and see if it runs good.
Seemed to not miss with the red rectifier wire unplugged. Is this also the charging lead for the battery? Was going to take it out to check just dont want it to die out on me?
Yeah just bought this one which i rebuilt for the seller just alot of gremlins i have two others an sp and a kaw 750 sx stand up. Seadoos just have a few quirky things im learning about
