Shop manual indicates the 93 XP has 657 engine, check model number (should be white tag on rear of seat pedestal) or last 2 digits of HIN are model year.
1 picture shows gray fuel line. Many threads here on the gray Tempo fuel line, bottom line is to replace the fuel lines with standard auto fuel line, clean out the entire fuel delivery system, clean or rebuild the carbs (new fuel causes degradation of the Tempo fuel lines which in turn cruds up the entire fuel system). Crudded up fuel system typically results in lean running which will kill the engine, sometimes in a rather dramatic fashion.
Welcome to the best SeaDoo forum. Snoop around, you will find lotsa good stuff. You will find this to be a friendly and helpful forum.
Good luck and have fun.
Rod
