Well, not the best pics. But in the first and last pics you can see the lines that should be aligned to each other. In the first look down between the 2 oil lines first you see the bleed screw then the post with the line thru it....in the last look at where the paint is missing and you can see a line . you match those 2 lines up.
MODS: I went to delete this post but I couldn't erase the pics...so I wrote an explanation instead. but can we delete pics, if so How?
