Hi, I'm installing the oil injection cable on a 787 engine ('96 XP) and the throw length seems to be too short. The throw length is 4.375" and overall cable length is 37" which I believe are correct for the OEM part. However, when I connect the ends to the oil pump and PTO carb lever assemblies, I am not able to open the PTO carb butterfly valve more than 3/4 of the way. It's as if the 4.375" of throw length is not enough for the carb and oil pump to have the required range of motion. I've checked the end connections multiple times and even removed the carbs so I could clearly see what was going on. I've compared my installation to the parts diagrams, reviewed the shop manual, and looked at photos and videos of the carbs and oil pump and I can't find a discrepancy to my situation. What could I be missing?
When I bought the ski the oil injection was deleted and I'm adding it back in.
Thanks!
Thanks!
