azsxr Active Member Jun 15, 2025 #1 I’m trying to install my carbs and the cable seems too short? When I install the cable it opens the throttle plates? What am I doing wrong? Thanks
mikidymac Moderator Staff member Moderator Jun 16, 2025 #2 Did you get the oil pump leg and carb leg swapped? throttle cable splits and works both. Also make sure you connect and adjust the wide open throttle switch.
