J Jcottrell New Member Jul 12, 2023 #1 Was running fine. Then just stopped mid ride. No power. Brought home checked battery, fuses, obvious wire connections. Still nothing. Has zero power to anything. Looking for some troubleshooting help
J Jcottrell New Member Jul 13, 2023 #3 skiasylum said: 30amp power relay Click to expand... Thanks. Going to get a multimeter to test it.
J Jcottrell New Member Jul 13, 2023 #4 Unfortunately not the relay. I replaced it with a new one. I can hear the relay click when i hit the start button. Still no power to anything
skiasylum Well-Known Member Jul 13, 2023 #5 Next is the start/stop switch, can test per manual or exchange for a known good, it can be stuck open or closed.
J Jcottrell New Member Jul 21, 2023 #6 skiasylum said: Next is the start/stop switch, can test per manual or exchange for a known good, it can be stuck open or closed. Click to expand... If the start/stop switch was bad, wouldn’t the gauges/screen atleast come on?
M MacSeaDoo Active Member Jul 21, 2023 #7 No, the start/stop wakes up the ecu. The key is only read after wakeup.
J Jcottrell New Member Jul 21, 2023 #8 MacSeaDoo said: No, the start/stop wakes up the ecu. The key is only read after wakeup. Click to expand... Thanks for the update. There isn’t much mechanical that I can’t fix. Electrical is my achilles heal. I appreciate the help from everyone
J Jcottrell New Member Aug 9, 2023 #9 Been away from this for a bit. Replaced the start/stop switch. Still nothing. Whats next?
J Jcottrell New Member Aug 9, 2023 #10 Actually it’s all set. Think the battery had died while i had it in the garage Just put a booster on it and its working. Thanks for the help
