Good day guys,
Question 1:
The other weekend my XP was tipped and it got a lot of water in the engine. It only beeped when the guy pushed the start button. Te next morning I went through the whole ritual of gettin the water out of the cyllinders. The ski started and seem to run fine. Unfortunately I had to leave for work, I had my fiance start the ski while connected with the hose and had her run it for about 15 minutes, she said it ran wothout any problems. Now my question is will the engine be okay? Was the 15min running enough to dry out everything?
Question 2:
Does my ski have one or 2 bilge pumps? The one white one in the back of the ski runs but does not pump any water out at all, even after switched off you can hear the pump running but no water is coning out anywhere??? When the ski is dried out inside the pump switches off so I would think the auto switch is all good. I just dont understand why it is not pumping out any water....
Thanks in advance for any replies!
Best regards,
Jacques
Question 1:
Question 2:
Best regards,
Jacques
