Noahsfixingbrokedownskis
Last year I changed my jet pump oil and used an anti-rattle cone. I have a 1996 GTI. When I did the cone I didn't get it perfectly sealed. Next time I'll do a pressure test for sure. This year when I went to change the oil to get ready for the season there was only water in the pump. The bearings still seem to turn fine. I pulled the pump off the ski and ran oil through it a number of times to clean out the water. My question is should I go ahead and rebuild the jet pump or should I simply use as is? I would assume water sitting in the pump all winter must be terrible for my bearings. I don't have the tools needed to replace the bearings. But im not opposed to buying the bearing pushers and a press. But it seems like the bearing pusher tool part 295 000 107 seems expensive for one small pusher. Are there any other alternatives to getting the bearing put in the right spot without that tool or am i missing a less expensive option?
