Jet pump replacement 2000 seadoo gtx PLEASE HELP
Hello, I have finally found the culprit to most of my problems, my jet pump was completely destroyed. It wasn’t even to the point where it can be restored. It originally was a 155mm jet pump, but the new ones are so expensive, so my question is are there any other models of jet pumps that would work on my 2000 gtx for a little cheaper? I saw something about using a 140mm pump or a pump from a newer model, but I don’t know if that’s true. Please help!
Go with the exact same pump. Sometimes people on this forum may have the parts your need. I buy 90% of my stuff from ebay. You should be able to find one at a reasonable price. You'll have to remove your impeller and reuse it if it is in good condition. You'll need new wear ring an impeller gasket and jet pump o-ring kit and pump oil. Check out osdparts.com which is a good start.
Do you need just the pump? (your impeller and nozzles are OK). No a 140mm pump will not fit, you need a 155mm.
Do you have the parts manual for your ski? if not get it , it will show you everything you need to reinstall it.
