Helping a friend fix his boat. No RPM, power up chokes out is what he told me. Only 93HRS total.
240 EFI V6 Mercury M2 Jet Drive
Oil light on dash stays lit. Only beeps shortly when key turned on.
I have read the ACTIVE codes- out of water, motor stone cold using 2 different code readers.
I added oil to the big tank, the little tank was full.
Starts easy out of water, only started briefly. Seems to smoke fine-(using oil).
Plenty of other previous codes, water in fuel being 1 of them, but not now.
PITOT CKT LO
OIL LVL CKT HI
FUEL LVL CKT HI
SEA TMP CKT HI
TRIM CKT LO
another code reader said
oil level sensor high code 82
Trim sensor circuit low 131
Lake/Sea Temp circuit high 104
fuel level circuit High 75
oil level sensor High 82
only oil sensor I see is the small tank. If I unplug the 2 wires, it beeps 4 times every 2 minutes with key on.
Sensor read .2ohms
any ideas?
Thanks!!
PITOT CKT LO
OIL LVL CKT HI
FUEL LVL CKT HI
SEA TMP CKT HI
TRIM CKT LO
Sensor read .2ohms
any ideas?
Thanks!!
