Dave, sounds like you might have stripped your threads.  Thats easy to do on an aluminum engine.  Those two bolts are torx head, M6X25 in size.  There are a couple ways of going about getting it to hold the rail down.  You can probably tap it up to the next size, or go to your local auto parts store and buy a helix coil to fit.  A helix coil looks kinda like a spring and when you insert it, put the bolt back in, the spring expands and grabs whats left of the old threads.  That might be your easy way out......
