Compression Is Right Around 150 In Both cylinders. I am not sure about the engine or slipping. We are not currently where we can run it in water.Also what is the actual compression numbers?
Is it reving and not going like a slipping clutch or the engine just won’t go any faster?
Did you check the plugs?
It ran the best after the fuel pump replacement. It then went back to running sluggish.I'm just getting into the RFI but did you or is there a place to check fuel pressure?? Save those parts you are replacing. Is there a chance you created a new problem when you did the work on the fuel pump and filters?? Did you test the TPS?? Check compression again. Happy Hunting.
The engine won't go any faster in the water.Also what is the actual compression numbers?
