2002 GTX RFI won't run over 30 mph.
mknice1
Messages
18
Likes
0
Water Crafts
2002 GTX RFI
#1
We purchased a 2002 GTX RFI. The cylinder compression is good on both cylinders. It stared out going about 50 mph, but now only goes about 30 -35 mph. Any ideas as to what might cause this?
mwat65
Premium Member
Premium Member
Messages
623
Likes
45
Location
kentucky
Water Crafts
kaw ultra 150, seadoo 1997 gti, 96 gti, 2-94 gtx
#2
Rectifier is known for going bad in the rfis.
mikidymac
Moderator
Staff member
Moderator
Messages
8,736
Likes
586
Location
California
Water Crafts
2003 GTI
2001 XP
1997 GSX
1996 XP
1996 HX
1996 SPX
01' Superjet
#3
Also what is the actual compression numbers?
Is it reving and not going like a slipping clutch or the engine just won’t go any faster?
mknice1
Messages
18
Likes
0
Water Crafts
2002 GTX RFI
#4
Compression Is Right Around 150 In Both cylinders. I am not sure about the engine or slipping. We are not currently where we can run it in water.
mwat65
Premium Member
Premium Member
Messages
623
Likes
45
Location
kentucky
Water Crafts
#5
Crawl under it and inspect the wear ring like Miki says you may be cavitating. Does it rev up ?
mknice1
Messages
18
Likes
0
Water Crafts
2002 GTX RFI
#6
I have changed fuel filters and fuel pump. My son took it out today. It ran great for about 20 minutes. It then dropped down to 11 mph. Any suggestions? Is there a way to check for codes without taking to a dealer?
mikidymac
Moderator
Staff member
Moderator
Messages
8,736
Likes
586
Location
California
Water Crafts
2003 GTI
2001 XP
1997 GSX
1996 XP
1996 HX
1996 SPX
01' Superjet
#10
12.3-12.5 with the ski off. Don’t want it to drop below 12v when cranking or running.
Messages
69
Likes
6
Water Crafts
96 seadoo gtx
#11
I don’t wanna disagree but a 12.3 battery is very low. A fully charged battery should be 12.7 12.8.
mikidymac
Moderator
Staff member
Moderator
Messages
8,736
Likes
586
Location
California
Water Crafts
2003 GTI
2001 XP
1997 GSX
1996 XP
1996 HX
1996 SPX
01' Superjet
#12
Just checked all mine and they are 12.5-12.6 for flooded batteries new and years old. Obviously higher is better mine are always on a battery tender.
The big test is it dropping when cranking.
mknice1
Messages
18
Likes
0
Water Crafts
2002 GTX RFI
#13
Update.
I have replaced the injectors, rectifier and the oil filter.
We took the ski out on the lake yesterday. It was sluggish and did not run well. It started out at only 3300rpm. It eventually made it up to around 4400 rpm.
Any ideas as to what the issue may be?
etemplet
Messages
1,470
Likes
93
Location
Louisiana
Water Crafts
1996 SPI, 1996 GTX, 1997 GTX
#15
I'm just getting into the RFI but did you or is there a place to check fuel pressure?? Save those parts you are replacing. Is there a chance you created a new problem when you did the work on the fuel pump and filters?? Did you test the TPS?? Check compression again. Happy Hunting. :)
Messages
27
Likes
4
Location
Chicago
Water Crafts
00 FTC rfi
99 gp800
#18
You said it ran fine for 20 minutes and slowed down. Random question: When you took the seat off was there smoke in the hull?
Messages
27
Likes
4
Location
Chicago
Water Crafts
00 FTC rfi
99 gp800
#20
Mine had a similar issue which turned out to be an old coupler from exhaust to noise suppression units. The smoke exhaust was filling the chamber and bogging down the engine. Only happened if I slowed down, I wouldn't be able to gain speed again. Once I found the leak it was a $10 fix. Did it same day as rectifier and fuel filters.
mknice1
Messages
18
Likes
0
Water Crafts
2002 GTX RFI
#21
It ran the best after the fuel pump replacement. It then went back to running sluggish.
Messages
69
Likes
6
Water Crafts
96 seadoo gtx
#22
Did you check k codes ?
Also take the crank sensor off and check for fillings since it’s an easy check.
Does your battery have more voltage now with the rectifier changed ?
Did you check to make sure you didn’t suck anything up in the impeller ?
Could it be a bad bearing in the shaft?
Messages
69
Likes
6
Water Crafts
96 seadoo gtx
#24
Sorry not sure where the k came from lol. You need a scanner. My local dealer scanned mine and didn’t charge me anything.
Users who viewed this discussion (Total:17)
Adsense
Usergroup
