Hey everyone,
Looking for some insight or shared experiences from anyone who's dealt with something similar.
I’ve got a Sea-Doo with the 1503 4-TEC engine. my 2002 GTX died on me while cruising a few weekends ago. I recently ran a compression test and found that two adjacent cylinders are about at about 40 PSI, the third is fine. The readings were consistent across multiple tests with a good tester and warm engine.
A bit of context:
Before I start tearing into it, I’d appreciate any ideas or suggestions:
Any specific tests, visual inspections, or next steps you'd recommend before pulling the head? Also, if anyone has seen this exact issue on a 1503, I’d love to hear how it turned out.
Thanks in advance — all input is appreciated!
A bit of context:
- The engine still cranks and runs, but you can tell something’s off.
- No major signs of oil contamination or external damage.
- It hasn’t been sunk or overheated (as far as I know), and maintenance has been decent.
- It's a 4-stroke, N/A 1503 (not SCIC).
- Could this point to a blown head gasket between cylinders?
- Burnt valves or valve seat issues? (but doesn't make sense to me to be two cylinders)
- Possible piston ring damage or cylinder scoring? (you'd think it would be only in one cylinder)
- Is this something common in these engines at higher hours?
