Codyco_2000
Hi , hoping someone could help me , I have a 2002 Seadoo Gtx 4 tec , which has suddenly stopped working. When I put the key on the machine I just get one long beep and the engine won’t crank .
not sure if it relevant but I installed a new Chinese cluster which seemed to be working fine , connected candoo pro to marry the cluster and it seems or maybe a coincidence but since then I get one long beep, the cluster will come on in full with the key attached but doesn’t go off fully when I remove it , it did when I first installed it
error codes are p1682, p1681 and p1680 when I look at the connections it says mpem and cluster , I’ve tried removing the cluster but still have the same problem - any help would be appreciated was hoping to take it out for the first time next weekend
thanks
thanks
