Well to start with im new here...
This is what I have.
I have a 2001 RXDI,I got it about 2 years ago. I had to rebuild the jet pump before I even got it on the water... But it ran fine for 2 weeks,then the RAVE valves locked up,fixed that,then it ran perfect! Then the compressor started leaking water....fixed that. Then the impeller took a rock... So I put a new impeller on it and repitched it and was getting a top speed of about 70mph. Then about a month later,it started to lose power. So I took checked eveything.
wireing
fuel
fuel press.
spark
compress. 150/150
pump
air compress.
air press.
fuses
also check for seizing in the crank and pistons
also checked the crankcase press.
and I finlly found it was the TPS on the mag. side was bad, so got that fixed and the computer reset to match the new TPS
ran perfect for 2 weeks
then died....
So I went and rechecked everything again....
and found its only injecting fuel on the MAG side.
So I check the injector and it works fine, checked the wiring its fine.
So can anyone help me???? Im about to give up on this thing
Thanks!
Matt
wireing
fuel
fuel press.
spark
compress. 150/150
pump
air compress.
air press.
fuses
then died....
Thanks!
Matt
