kseidehamel
I was out running my 2000 GTX RFI this weekend and after about 45 minutes the hi-temp light flashed and the engine promptly shut down. I towed it home and let it sit overnight. The following morning a tried to turn it over and the starter engaged but wouldn't turn the engine over and I couldn't turn it over by hand either. I then took the head off the cylinder to look at the pistons and they looked fine as did cylinder walls. Also took a peak at the rings through the rave value holes and everything looked good. After putting some 2-stroke oil in each cylinder and letting it sit, the engine started over and sounded normal. Not knowing that the issue was, I buttoned it back up and took it back out and she ran perfectly for 30mins and then shut down again. Hi-temp light was on again and now it wont crank. Jet pump was fine, I removed and spun by hand.
Could I be having heat seizure due to lack of oil? Cooling system checks out. Im leaning toward oil pump or clogged oil filter. Hoping its not bottom end damage causing heat. How do I check oil pump? I don't see any bubbles in the oil lines but I don't know how to verify if oil is getting into engine. I haven't noticed oil level dropping much, but I haven't run it much this season. Plugs look nice and brown.
Should I start with oil pump? Other ideas. Any help is appreciated.
