1998 GTX Limited 5937 Fuel line to fuel pump
RexMcG
I replaced the grey lines and cannot remember where the line direct from fuel tank connects at fuel pump - see attached pic. There is a tee connect above a 90 degree downward facing connect. One is left without a line connected to it I believe. Can you tell me where the line should connect at?
If you talking about the fuel connection that is on bottom side of carb. that you cannot see in picture that line is fuel line into carb from fuel strainer. The line on the 90 is pulse line to crankcase.
