murray1886
Has anyone tried to drill and bolt a slipping 787 xp PTO?
Its an xp....the pto and the coupler for the drive shaft are 2 pieces held together by a rubber ring.... the rubber had failed and is slipping under torque
Click on the link in my last post, you'll see the parts diagram, it's part no. 23. From your description it's very hard to understand what you want to do. Use the parts diagram to identify the part(s) you want to bolt together or replace or drill. I'm probably not understanding your question.
Lou
I want to know if anyone has just retrofitted to old style by drilling and bolting to make it like the newer design.....and no....the newer design won't fit this engine
You can't replace the coupler..... pressed together...one piece....and a discontinued part....
Make this easy post a dang picture of what you are talking about since you think no one knows what they are talking about.
Its the PTO....go put one in your hand and you'll know WTF I'm talking about. You re not going to see it in your book the pro is machine
which part number on this diagram are you talking about, the PTO doesn't have any rubber pressed onto it, the bumper that goes inside and the coupler are replaceable. so WTF are you on about?
Have you even looked at the parts diagram that was posted? This is from the SeaDoo official parts manual, it's the way your ski was built. If your ski is different then maybe the previous owner modified the drive system or used an unknown aftermarket part.
Since you won't cooperate by giving answers to our questions or posting a picture, I'm out of here, good luck with your project.
Lou
