dbalayti
Hey all,
First time owner here..I recently purchased a 1996 xp 787 and I’m having issues starting. I’ve attached a video of the solenoid clicking (I believe). I’m assuming I need to rebuild the starter? Once again first time owner so I really appreciate any feedback!
Thanks,
You could have a bad solenoid so jump across the top to energize the starter. If that doesn't work I'd remove the spark plugs and energize the starter again. Try rotating the crankshaft by hand next then check for something in the impeller if the crank doesn't move easily. You want to verify the starter is the culprit. If the starter is OEM a rebuild kit is the best way to go. I generally just replace the brushes, clean the inside of the starter, clean the armature, etc... make sure you seal it good when you're done. Good Luck !!
Thank you!
