achtungbabi
HI Everyone, well it has happened finally the boat is finished and ready to take out and as we all know, something went wrong.
In Summary one of the engines will not start.
The twin battery set up has been changed to a single type doing the start up modification.
Before the mods both engines started one needed the "Two battery switch" to really turn over.
The engine directly behind the steering wheel started stronger than it ever has. Not so much as a question - just wham and start.
The engine close to the oil filler / passenger side will only give a few clicks and thats it. nothing more.
Any ideas?
I do notice that the Negative and positive wires to that engine are getting extremely hot to touch after continual attempts to start.
The spark plugs are not in the greatest of shape.
Im not getting any "cranking" when putting the igintion leads onto the grounding plate. just a loud click and then a "whine"
Have also had to remove the switches and replace due to faults. All have been checked and found to be working. I know dont have the "twin set battery" set up - should the two wires for this be connected or just left taped in the steering wheel bay?
The battery in use at the moment is one that that is a deep cycle and recomended for Large 4 wds.
I do have a long continuous squeel from the beeper that seems to get louder at each attempt.
should i go back to the twin battery set up and see what happens? - Really dont want
Any help will be valuable as im trying to sell the boat and what it gone quickily - Boss has the foot down.
Any ideas?
