Help! 01 Challenger 720 weak spark?
Austin69
Premium Member
Premium Member
I rebuilt both engines in my twin 717 01 challenger and installed the left engine and it has new carbs too that worked perfectly before but it wouldnt start or have any sort of combustion and i installed the rotary valve and magneto/armature plate correctly and did a spark test and it seemed really weak i had to turn the lights off but now im seeing on forums its normal. These motors ran before why wont the left engine start? I havent installed the right yet btw.
Are you assuming the problem is weak spark, or did you test for spark vs. fuel?
Little bit of premix (or whatever 2-stroke safe "starting fluid") in the spark plug holes will catch at least once (good spark) or not (bad spark).
