cuenta New Member May 31, 2013 #1 where I can buy the large 5.5mm socket to disassemble the storage comparment. and replace the gauges I have several 5.5 mm, but do not fit are way too thick
Jetskigoodies Well-Known Member May 31, 2013 #2 You need to use a nut driver, and you still may need to grind the sides down a little. http://www.lowes.com/pd_121593-8658...er&pl=1¤tURL=?Ntt=Nut+driver&facetInfo=
Coastiejoe Moderator Moderator May 31, 2013 #3 I was going to suggest buying a cheap 5.5 and grinding the sides down as well...
black&yellow96 New Member May 31, 2013 #4 You shouldn't need to pull the whole thing apart to replace gauges just take off the inside cover and unplug from there.
Jetskigoodies Well-Known Member Jun 1, 2013 #6 You need to make this tool. I have and it works great. [MENTION=57920]racerxxx[/MENTION] has a how to thread on the tool. http://www.seadooforum.com/showthread.php?58235-Seadoo-2-quot-Gauge-Removal-Tool
black&yellow96 New Member Jun 2, 2013 #9 Go to harbor freight and get a set of these the 5.5 m&m works perfect!
C chucked Member Jun 2, 2013 #10 Yep http://www.cornwelltools.com/webcat...TS047SS-%2d-47-Piece-1{47}4”-Drive.-Super-Set
cuenta New Member Jun 2, 2013 #11 thank buddy. I will buy a set /// Last edited by a moderator: Jun 3, 2013
black&yellow96 New Member Jun 3, 2013 #14 Yea I had just got them yesterday and remembered your post haha.
