Flooded!....
It is possible that they have been under too long. The engines and electrical systems can survive being flooded, but action has to be taken real quick. Time is of the essence.
Right now, lets try and free the engines up. Go out and take off your drive shaft guards on the back of the engines. There are two plastic wing-nuts that hold them in place. Then, take out your plugs. You'll need to get some Marvel Mystery oil, comes in a red can from your local "Autozone" parts store, and pour liberally into your spark plug holes. Then, with the shaft guards off, take a pipe wrench to the shaft and try to turn them. Preferrable counter clockwise. If they won't turn right away with a little force from the wrench, let the Mystery Oil soak a little. In the meantime, take off the flame arrestors and spray WD-40 liberally inside the carbs, especially the one with the rotary valve in the open position. That will go straight to your crankcase. Spary all the linkage and really the entire engines.
Then, after letting the Mystery oil soak for about an hour, try to use the pipe wrench on the shafts again. The longer the engines sit, the harder they will be to free up. I hope you just drained the water. Because the water would keep them from seizing. Seizing occurs after the water has been drained from them. That's when they start to rust.
If you can't get the engines to turn over soon, then you might as well go ahead and pop off the head covers so you can take a look at the pistons. This will be a good indicator of how much water got into the engine (you'll need two head gasket sets, about $100 bucks each). If there is water standing in the pistons, then they really got flooded.
You need to also take off the electrical box covers and see if they got flooded. They are sealed, but that doesn't mean they didnt' get water in them. If they did, spary WD-40 in there too. The MPEM is suppose to be a sealed unit. It may be o.k., also, check all the fuses.
Let us know how you come out so we'll know what steps to take from there.
Oh, if it makes you feel any better, I forgot and left the plugs in my Challenger too. It filled up with water from the rain, but I caught it just before it reached the carbs. This is how the water gets into the engines.
