Hi there:
Got my 1998 challenger on the lake yesterday and on one engine there is a slight leak from the carbon ring assembly. Its not too bad and if I turn on the sump pump every 15 min or so it clears it out with a matter of seconds. If I reach down there and pull the rubber boot back from the silver fitting then water seems to gush in at a much faster rate but as soon as I release the rubber boot it goes back to a trickle.
I'm only finding this on one engine. The other doesn't leak at all - even if I push the rubber boot back.
Wanted to know if this is normal and if you can run it like this for a while - ie: will a bad carbon ring create enough of a leak to sink the boat? Was hoping to wait till the end of the season before I start pulling this stuff apart.
Many thanks in advance for all your advise.
