Strizzo
The wire tie will tell you if there isn't enough pressure on the surface due to wear of the carbon ring. As long as there is meat left and a bit of pressure it shouldn't leak. I've seen them worn down almost to the bellows and not leak. If the seal is cracked no amount of pressure will seal it. I'd look to the wear ring as you already need to take a good bit of the steering parts and nozzle off to change the pump oil, which should be done anyways if you haven't already. Changing the wear ring is only a few more bolts and another couple hours of work.
