project_seadoo
ill start off with how this all came about i brought a 96 seadoo xp 787 as a project, decided straight away to replace the motor
so i brought a recon exchange motor from jet sport QLD australia at a cost of 1750, had my carbies rebuilt at a cost of 500
i replaced all fuel lines and all other hose in the ski while i was at it, had new plugs welded in the exhaust while it was out as i didnt want problems later on, new wear ring and performance impeller in the jet unit.
took it easy for the first 5 hours with oil added to the fuel for the break in.
just before the easter long weekend here in australia i took the ski in for a service an tune so i wouldnt have any problems throughout the weekend
in the report from my mechanic he noted the rear cylndier (pto) was running rich an he adjusted the carbys
he also noted the bores in each cylinder looked perfect.
so i was very happy an set for the week end
we arrive at the river and the ski seems to be running great but would sometimes just die,i didnt think to much of it and kept ridng
the next day it was hard to start in the morning but was fine when warm but began to die at WOT by this stage the motors got around 8 hours on it
so i loaded it back on the trailer.
once i got home i decided to commpression test it mag side 153psi pto side 30psi
so i began to tear it down and heres the pics of what i found
and also a pic of the mag side still showing cross hatch on the bore
this engines at .25 over size, i shaved a bit of the raves for clearance even though its not needed till .50OS
as far as rebuilding this what would you guys do bore both cylinders to .50OS or just do the pto cylinder and the mag sides perfect?
now im wondering what caused the pto to fail? could it have been my mechanic adjusting the pto carb causing it to run lean?
any other possible causes?
would appreciate any help thanks guys
